Arlo VMB3000 Stuck At Amber Power Light
I recently restarted my Arlo VMB300 and all lights briefly flash green before the power light remains a solid amber. I tried a factory reset by holding down the reset button for 30 seconds and nothing happened. I also unplugged it for five minutes and restarted it with the same results.
Swap at the store or open a case with support using the Contact Support link at the bottom here.
