Arlo Pro rechargable battery won't charge - flashes from 54% the 0% then back to 54% etc.
My Arlo Pro cameras have been working very well for the past 3 months, but one of my Arlo Pro's batteries is not recharging correctly.
Problem: When trying to charge, it charged up to around 54%, then keeps flashing back and forth saying it is at 0%, then back to 54%. It has been charging for about 5 hours, and hasn't gone up any further. It sometimes disconnects completely, so I have to pull the battery out and reset the camera back online.
I narrowed it down that the problem is the Battery. I tried swapping a new camera, and the Problem battery, and got the same results.
I tried using the Problem camera with a different battery, and the battery charged fine.
Anyone else have this issue?
Hardware problems can only be solved by opening a case with support using the Contact Support link at the bottom here.
