  • 5 Replies
  • 1484 Views
DB74
It doesn’t work when following other posts and going through mode and editing a schedule. What am I doing wrong ??
DB74
Thanks I got this sorted. Problem was I was looking in schedule which was the mode I was on. Not in ‘armed’ which was where I was able to see it.
To make it more intuitive, I would have thought that schedule should have the same options as armed…or schedule is nested below armed. Sorted now thx.
5 REPLIES 5
Dannybear
Refer
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Are you trying to acknowledge the siren or trying to disable it when motion detected.
I think in the ultra the camera siren is selectable within the camera rule.
If you look at the camera rule in the mode, you should see this:
Make sure the check box isn't checked.
DB74
DB74
Hey was trying to disable the siren that is activated by motion detection. Sorted now. Thx
It's not particularly intuitive.  The hierarchy (FWIW) is
  1. geofencing
  2. schedule
  3. modes
  4. rules
geofencing engages two modes (one when you are home, the other when you are away).  One of the modes can be schedule (which technically isn't really a mode).
Schedule lets you schedule modes.
