Arlo Smart Home web site can not change month to December
Hi Community,
I wish to change the date on the arlo website library to December however, it just shows January.
I don't see any way to change the date, I'm using Chrome
Thanks for your support.
On the left side, near the top, under the word Library is a "<" (mine also shows December next to the "<") - click it to change the month.
Thanks for your reply. Unfortunately, I don't see the month naivagtion icons < > please see the below image .
The issue, as shown in the image you posted, is that you have the basic free plan which only goes back 7 days. Since we're well into January, there's no videos to see after the 7 days are up, including in the previous month. If you had a paid subscription, you would have the ability to see the prior month's videos, up to the point where the system would then delete them after the appropriate number of days.
Thanks Support,
I have been informed we pay $140 p/a so we can review footage. I can see and replay events in December but they do not appear in the December Library. Is there something I need to do?. Also, how can I tell to which Arlo plan we are subscribed ?
Cheers,
Ramesh
