Arlo Secure Mobile App Upgrade - Cant Find Device Settings
  • 2336 Views
dtmhiggins
Recently Arlo 'upgraded' the 'Arlo Secure' Mobile App. The navigation in both the Ipad/Iphone IOS version of the App seems very limited and I'm not able to get to very basic information such as Device Settings. The App opens to a Dashboard view and has available buttons for Dashboard, Feed, Emergency, Device, Routines. If I go to Devices it shows a high level view but I'm unable to see basics such as battery level percentage. Does anybody know how to get to the 'Device Settings' windows?
Just go to "Devices" and touch the image for the camera (or base) that you want to control. If you touch the base, you'll go directly to the base settings. If you touch a camera, there will be a settings wheel in the upper right of the screen.
RL90
Not only can I not find the device settings there is no obvious way to exist a camera view without closing the app and restarting it. Is this a beta release or just a joke?
The previous app worked well. I don't really want to bother playing hunt the device setting. How can I revert to working app from this mess?
ShayneS
@RL90
Have you tried rotating your device from full screen or pressing the expand/minimize arrows in the corner of the display?
