I just bought a combo with 3 Arlo Pro and the base. But I'm having problems:
I could not configure the base with my router. So after reading some forums I took the base in a friend's house and I was able to configure it, and also the 3 cameras.
After doing that I installed it on my router and apparently everything was fine. But when I pull away any of the cameras about 3 meters from the base it automatically stops working.
Is someone also having this problem or know what the solution is?
There must be some interference in your house. What wifi router have you got?
My router is Arris model DG1670A
ccastanhola,
Consider moving the base station away from your router (as much as possible) and try again. Do you still see the same behavior?
