  • 4 Replies
  • 4251 Views
klattorney
Arlo Pro purchased from someone else.  The internet LED on the front of the base station does not light green and not getting internet.  I am using Cisco,  Linksys E1000 router. Please Help. Im new at this.
e1000 routerPlease help with this.
What color is the Internet LED? Off means bad port or cable. Amber means it's connected to the router but not the servers.
klattorney
The color on the base station is amber
klattorney
What do you mean "not connected to the server? I am very new at this
Arlo cameras need to connect to a remote server (the cloud). Since your LED is amber, something in your router settings or the ISP connection is blocking access.  WHo owns your router - you or the ISP?  If the ISP owns it, you'll need to contact them to ensure that ports 80, 123 and 443 to arlo.netgear.com are open.  If the router is yours, try turning it off and back on. Worst case, you may need to reset the router to the factory configuration.
