Arlo Pro wifi camera
Hello everyone,
I just set up my Arlo Pro wife security camera base station and account on App. Everything is working fine i have internet connection and power tabs showing green. My problem is syncing any of the 3 cameras. I get a blinking green on the base station and Blinking Blue sync button on the camera but it will not sync. None of the three cameras and I've tried consistently over an hour. Eventually the camera finally flashes a rapid amber color indicating the sync was unsuccessful. What suggestions do you have what have i not tried yet? Frustrated!!
Thomas
The usual problem is that you're holding the base sync button instead of a quick press. However, that's not the only possible problem. It might be worth removing all devices (just the base, based on your description) in Settings, My Devices and start fresh. Use the reset button on the base and hold until the LEDs flash amber. Let the base restart and then use the Add Device button on the Devices tab to add the base again. Can you then sync the cameras?
Power cycle the base and pull the battery to reset both to a known condition. ANy help?
