Bought the Pro mainly to have the ability to speak through the camera when someone's at my front door the sound out of the Pro can barely be heard I would say you have to be two feet away to be able to hear. a
Anyone experience this?
I know that was never explain. I was on the phone three times and they always gave me an case # ,when I called back giving them that case # made everything run smooth . I feel my camera is taken care of and they gave me another case # if I had to call back
to add I feel everything was taken care ,with the fix, in a good manner. I can not complain , they did respone back to me via e mail.
Unboxed and set up my Pro 4 camera on Saturday. It loaded a bunch of firmware in the process and my audio was excellent from the start. No issues with the magnetic mounts keeping the cameras in place as well. So far so good.
Norm547 wrote:Let see I am rying to understand this. If it is a mobil app why has Netgear informed us . I have apple 5s and 6 plus and it does the same in both ,low audio . It seem that they should adress the issue
It is the app. We are waiting to see if they update it. The firmware change from four days ago had nothing to do with the audio issue. They have just started looking at the audio issue now and say it is a problem with the app.
I've tested audio out with a meter on several different platforms (mobile apps and web based app on PC) since the firmware. No change.
Yes I know ours i coming though great . That update did the trick
A firmware update was released that should resolve the low speaker volume issue for Arlo Pro. Be sure you have the latest Arlo Pro camera firmware (1.089.0.1_9815) along with the latest Arlo mobile app versions installed.
Yes thank You My camera is working great . That update work perfect. I am now going to see if firmware is set at 1.089.0.1.9815
Thanks it works much better.
Bob
If you go to your my arlo insettings update 1.089.0.1.9815 is ther to fix audio or if you are not sure call support and they will help you. They help me ..
I called 408-638-3750 or 888-638-4327
Not sure I have apple ios 10 . the update firmware they gave me is 1.089.0.1.9815 call support to check for your system
1.090.0.0_9945 is the latest camera firmware - can't speak for iOS app version (check the firmware/release notes area here).
My Android app is the latest and still has the issue since the cameras are outdoors. Indoor volume is fine.
I suspect a long-term fix will be in place but we have to wait for the app to be updated to support that. Since the computer works fine, it's an app problem.
One thing you can do is to make sure you speak loudly and directly (~2 inches away) into the actual mic opening. It can be cumbersome and isn't the way it should be but until a fix is applied, it's the best you can do.
I'm a new user here. I have 2 Pros and 3 non now. Pros are running the ....9945 firmware. I am having an issue with the speaker audio as well. Pros are mounted about 6 feet from where someone would be listening. When talking through the speaker, using my Android S6 edge or Note 5, the sound is low. After looking through this thread and one other, I tried it with my laptop. Sound is much better, not great but much more audible to get attention.
App on phone is version 2.2.3_15049 released on 11/15/16.
Are we still waiting on an update for the app? OR, what is wrong on my end?
