Arlo Pro vmc4030 will not sync
  • 4 Replies
  • 1873 Views
ilaudio
My father in law had a camera that will not sync on the base station it used to sync on. He tried all the steps in support to get it to sync. I took camera home to try and get it to sync on my base station. I can't get it to blink blue at all. Or amber after holding for 15 secs. Any ideas?
There is no way to reset a Pro camera.
This sounds like it might be power-related. When you charge the camera, does the LED show a solid blue status?
ilaudio
I charge the batteries with an external charger. I did put a full battery in and plug in a charging cord...it blinks amber several times then stops blinking.
I would surmise that the camera has a fault. You'll likely need to replace it. You could temporarily purchase a single camera subscription that would allow you to contact support but I'm not sure they could help unless the camera is within the typical 1 year warranty.
ilaudio
Darn. Ok thanks for help. It's a few years old so I am guessing he will buy a replacement.
