  • 2 Replies
  • 5160 Views
SteveLX
Could someone please tell me what the actual viewing angle is on the Arlo Pro. I had an Arlo Pro 2 on my back porch and moved it to my driveway I took the Arlo Pro that was on my driveway and moved it to the back porch mounted both and the same exact position that they were and my viewing angle is smaller on the Arlo Pro versus the pro2. I thought both of these cameras had 130 degrees
DaveWoj
Virtuoso
Virtuoso
Although the specs say FOV (field of view) is 130 degrees for both it may have something to do with the resolution.
That is just a guess.
I know that the FOV changes on my Arlo Q depending on the resolution I choose.
With both at 720, is the FOV the same?
We've been told that the Pro actually is a bit less than 130 degrees while the P2 is a bit more, hence the difference you see. The new sensor in the P2 likely means new optics so an exact match to previous series isn't possible.
