Arlo Pro system refuses to remain armed after I armed it through the app. Shows disarm later.
I have been noticing lately that my Arlo Pro system refuses to remain armed after I arm it with the App. It shows disarmed if I check the App again after an hour or two it seems. I have noticed this using both the standard Armed mode and with the Schedule mode. For a system designed with security in mind, an uncommaned disarming is a serious flaw.
Unfortunately, the appps can have issues displaying and setting anything under the Mode tab. I use only a browser for this since it has proven to work properly. You can use a mobile browser if you set it to use the desktop version of the site.
Thanks for the tip. Hopefully this gets addressed quickly.
