Tomorrow morning it will be -24c, should I have to bring al cameras back to home?
Yes, it's a design decision. I don't know why the cameras shut down at these temps but it's normal. Warming them up is a workaround but they will stop once again when cooled off. The original wireless cameras work fine at much lower temps with both the non-rechargeable OEM batteries as well as the rechargeable ones.
i have 2 cams outside. last night was 11F (with wind chill close to 0F). they were active and this morning both cams batteries dropped more than 20% (1 cams had 5 motion recordings, about 10s each). The cams normally use maybe 2% of battery when taking 20+ recordings when the temp was above 32F.
Maybe jguerdat can confirm this, but shutting down has nothing to do with it running on batteries.
I have 2 that are hardwired and the same thing happens.
I have 2 Arlo Q's indoors unheated (another location) at the same sub zero temps and they have never stopped working.
I can't imaging that the batteries can last very long after being subjected to 7 days of these temps. That's why I hardwired them from day 1. Way to much of an inconvenience and danger to get up on my 8 ft ladder to change out a battery in that weather.
Stay warm Arlo friends.
Sorry, can't confirm since my cameras are out of reach from a power outlet.
