  • 2049 Views
frontsight74
Its 43° outside and my camera still says it needs to warm up? Is there a way to reset it?
Remove and reinsert the battery to reset the camera. You may also need to reboot the base, too.
frontsight74
So then I need to mount these in a more accessible location? It's on a solar panel and a ladder is required? Not acceptable to take battery out everytime it does this.
I have one camera that seems to be calibrated to a higher temp, too (cuts out above freezing, turns on well above). It could be replaced by opening a case with support ofr the rest may fix things.
