What is the range of the night vision on the Arlo Pro security camera
Good to a max of about 20-25 ft...
here's a pic of at night, the short stump in middle is aprox 30ft, the camera is mounted 6ft high
If you angle down more from a higher point, the IR will cover less distance.
