I have recharged a couple of my cameras before without a problem but now I get the same message on each camera I try to recharge which is that I am not using the Arlo Pro charging unit - trouble is that I am - is there anything I can do?
If you're sure that your connections are good, you'll likely need to open a case with support for bad hardware. Could be the power supply, cable and/or camera is at fault.
You can try a different cable to see if that helps. Also, a phone charger that supports Qualcomm Quick Charge (5v and 9v) should work if you happen to have access to one. Have you removed and reinserted the batteries?
