  • 2 Replies
  • 2015 Views
Jaicee
Will the Arlo Pro work with full functionality on a home wifi network where the internet access is through a 4G connection? My current ISP is through 4G as I don't have fibre here with the only alt being ADSL which is very slow. However I know the ISP does not allow port forwarding as they use CGNAT on the 4G network. Will the Arlo Pro work as intended or not? I know my previous IP address cameras will not work anymore since I made the switch to a 4G ISP.
Jaicee,
What speed is your 4G connection (download and upload)? Take a look here for minimum requirements: What are the minimum requirements for installing and using my Arlo system?
Jaicee
Hi my 4G speed is fine. The question is whether the live stream will work given the ISP does not allow port forwarding as it uses cgnat protocol. I searched and hv not found a direct answer...
