Arlo Pro night vision not working properly
  • 4393 Views
Mikey63401
MY night vision not working properly. The LED lights light up but the video is mainly black or too dark to see anythinhg at 6 ft.It worked fine in the past
Pull the battery pack and replace it to reset the camera...
Test night vision again
If still NG, contact Netgear support
Mikey63401
Thanks for your reply. That has already been done. Contacted support
Sammiegrace
I found that my pro2 night vision was ghosting white at night , however, the camera worked great in the daytime. I found out that the problem was none other than condensation on the lense. I took a rag and wiped the lense PROBLEM SOLVED. I dont know really why maybe cuz it has been very cold at night and warmer in the daytime or the camera generates heat , anyway I dont think there is a problem with firmware as I have seen other folks suggest. Im thinking of making some small bird houses if the problen continues , thus far it hasent. 😉
