Arlo Pro motion detection miss big
  • 2 Replies
  • 3886 Views
frenchsun
When I decide to detect a specific zone , i did a parameter on mycam and used the zoom & frame option.
But As the cam still detect what wasn't on this frame ... I decided to reduce the motion sensibility to 10%.
So I did a test with my white shirt... and moving on this frame do not engage any alerting !
But all movements not in the frame still succeed !!
Zoom and pan won't change the detection zone. It simply​ crops what you see but the detection is not cropped. You probably​ need to tilt or reposition the camera so it doesn't see the extra area.
frenchsun
hmmm that s mean this cam is unable to work far !
if you put it not at close range, zooming or framing is useless for detection.
Resizing the picture do not change its center of detection.
User view it sounds as a bug !
thx anyway
