Arlo Pro motion detection miss big
When I decide to detect a specific zone , i did a parameter on mycam and used the zoom & frame option.
But As the cam still detect what wasn't on this frame ... I decided to reduce the motion sensibility to 10%.
So I did a test with my white shirt... and moving on this frame do not engage any alerting !
But all movements not in the frame still succeed !!
Zoom and pan won't change the detection zone. It simply crops what you see but the detection is not cropped. You probably need to tilt or reposition the camera so it doesn't see the extra area.
hmmm that s mean this cam is unable to work far !
if you put it not at close range, zooming or framing is useless for detection.
Resizing the picture do not change its center of detection.
User view it sounds as a bug !
thx anyway
