Arlo Pro motion detection does not work
  • 1 Reply
  • 2275 Views
jpizarro
Hi Guys,
I have critical issues with my ARLO PRO , the motion sensor do not work properly so any motion is reported and is very anoying , is like the sensibility is always in 100% but actually is under 20% . I tried removing the battery and removing the camera from the base and added again but the problem persist . I recieved a notification every 10 seconds for nothing .
Please your help
Have you set the sensitivity in your modes properly? ALso, have you positioned the camera(s) properly to minimize the false triggers? There are FAQs here that detail this.
