  • 6 Replies
  • 5139 Views
  • 5 In Conversation
xltima
I have a custom mode created works fine however just recently I cannot get it to stay in that mode and keeps reverting back to Armed by itself. I'm using Android app.
6 REPLIES 6
Try restarting the base. Are you using the schedule or just selecting your custom mode?
xltima
Just selecting it, and then it actually switches on me after I refresh the tabs. So far the only work around is to use Geofencing and set both Away/Home settings to the same mode.
I just rebooted it and now two of four of my cameras are showing offline and the same issues still occurs when I select my custom mode.
xltima
So after several reboots through the web portal, I had inconsistent reconnections with cameras. So I ended up unplugging the power completely and let it drain out. Then powered it back on and everything came back up. So far the modes are sticking.
Orius
I have the same problem with the android app since 5/14/18. Never had this issue before with modes not sticking. The odd thing is that when i log into my online account, the modes display correctly but on the app, they don't seem to stick.
-Rebooted all of my base stations but no change.
-Uninstalled-reinstalled the app but same thing happens.
Wonder if if the latest app update for android that caused it.
MitchellH
I'm having the same issue as OP. Seems to be the last app update.
For those experiencing this issue, are you using a schedule? If so, do you see the same behavior when select the custom mode only?
Have you tried creating a new custom mode, does it behave the same?
