My camera's 3 of them Arlo Pros are giving false audio. My other 4 cameras do not. They have firmware 1.092.0.5_13833. How can I fix this? They are running my batteries down.
Have you changed the audio detection settings in your modes/rules? DO you need them in the first place? Have you determined what's causing the detections, such as something nearby setting it off that you didn't expect?
Sometimes removing the cameras from Settings, My Devices and resyncing helps.
I have audio turned off on all the cameras. I believe the wind is setting them off. I have big oaks in my yard. I tried turning cameras off for 1 hours and back on and it was quiet for a while and then they starting sending notices again. I have not tried resettilng them or re-syncing them. I will give that a try.
