Arlo Pro - date in Library revers to September
All of a sudden three days ago when I check camera the date appears in September versus February. Have searched and see no way to change it. My computer is set on the right date and time. Thanks,
reboot the base unit... power button off then on. let it come back online( 2-3 mins )
pattycake192,
Have you tried viewing the library from a different device? Do you get the same results? Are you still experiencing an issue after a reboot?
Thanks for the tips. I can view just fine on my cell phone. Have rebotted the computer twice to no avail.
How about flushing the browser"s cache as well as trying a different browser?
That did not work either. Think I have gremlins!!
pattycake192,
What browser are you using? Did you try a different browser and get the same results?
