Battery status was showing 21% so decided to recharge. Keep receiving a charging fault message with advice to unplug and reconnect from camera side of the plug. Have done this to no avail, have also removed battery from camera - waited 30 seconds and replaced - fault persists, removed camera from base station and re-added device - fault still persists. Am using the same Arlo charger plug and connecting lead as I always do - anyone experienced same or have any ideas on how to solve?
Thanks for the suggestion. Bizarrely, I just tried the charger again today and all has worked fine! I thought I may have been experiencing the same fault that others on this forum have reported though I hadn't been able to find a reported solution. Anyhow, all seems OK again now - thanks for your time.
Have you tried charging another camera to verify that the charger is working properly? If that works, try swapping batteries around.
