Arlo Pro changed recording settings
Have Arlo Pro set to record on schedule. This morning, way past the schedule time, it recorded me sweeping the drive. When I checked the settings it was on Armed. I did not change it. No one else has access. Lost connection to router yesterday and it had to reset. Would this have caused it to change the settings from Schedule to Armed? Glad it didn't reset to Disarmed, but still! Would be nice to know that is something to check when power goes out.
Have you tried to reboot the base station since you noticed the issue? you can try and switch off of scheduled mode and then back on over the web portal and keep an eye out.
