Arlo Pro camera stopped recording
  • 5 Replies
  • 1457 Views
GV60
I saw earlier post by @commodon related to their Arlo pro H8 cameras no longer recording but I could not see what the solution was to get them recording again.
i am looking for guidance as I too
have 3 cameras that have all stopped recording. (H7 , H8 and H11)
What was the fix here as solution does not show anything.
your help is much appreciated!
thanks
Best answers
  • ShayneS
    @GV60
    Would you mind trying to remove the Schedule you created and just set the mode to Armed and trigger motion again, and view the motion detection icon to see if it illuminates amber.
5 REPLIES 5
ShayneS
Hi @GV60
Can you provide more detail regarding the symptom you are experiencing?
GV60
Yes for sure
Yeah one by one each of the cameras have stopped detecting motion and do not record any motion / or stored videos automatically
they will snap pictures manually or record manually via the app and you can see these under the device
but no automated recording of video la driven by motion.
I have tested the motion detection light via the app and that does not work either
I have rebooted the Arlo base station multiple times
I have removed and re-added the devices without success.
so not sure what the next step is
ShayneS
Is it possible to see if they record to local storage?
GV60
I just added local usb storage
still nothing records based on motion for any of those devices
I have two VMC3040r6 that both record ok but they are plug in powered cameras
ShayneS
@GV60
