Just installed two ArloPro cameras but the one at the front of the house and furthest away from my wifi router and Arlo Base, is receiving weak signal and is mostly out of range or it is buffering continuously. However my router is located in the basement and at the furthest point from this camera.
Any suggestions on how I can improve the signal reception at this camera? The other one is working fine but it is much closer to the router.
Thanks in advance.
Jimbo
You need to get your base station to the most central location (in relation to the cameras). If you can't wire it or move the router, consider a range extender and plug the base station into that
http://www.netgear.com/home/products/networking/wifi-range-extenders/
If you can't centrally locate the base to work with both cameras, the only real answe is to add another base ( via cable or wifi extender ) so the second camera will be in range.
There is no limit on the number of bases used on any service level.
