Arlo Pro battery not charging. Can I get a replacement battery?
  • 1438 Views
Ron20
Battery not charging, didn't last one year. Can I have a replacement battery? I used my charger on my other cam and it charged.
If your battery is completely dead and does not charge, follow these troubleshooting steps:
Remove the battery from your camera.
If your camera is plugged in, unplug your camera’s AC power adapter cable.
Plug your camera back in to the AC adapter that came with the camera.
Make sure that you are using the power adapter and adapter cable that came with your camera. A regular 5V USB cable cannot provide enough power to charge your camera’s battery properly.
Reinsert the camera battery.
After ten minutes, check your camera’s status in the Arlo app or at arlo.netgear.com.
If you see a lightning bolt battery icon, your battery is charging. If you do not see a lightning bolt icon, continue to step 6.
For more information about Arlo battery icons and notifications, see How do I interpret my Arlo camera's battery level icons and notifications?
#6 Remove and reinsert the camera battery, then wait ten minutes and check your camera’s status in the Arlo app again.
Repeat step 6 until you see a lightning bolt battery icon in the Arlo app.
If you repeated step 6 five times and you still do not see a lightning bolt battery icon, contact Arlo Support to speak to an expert.
Ron20
Thank you. I did all of these but still no luck. Anyone has a number of the Arlo support expert?
