Arlo Pro base station not detecting USB device after insertion. Already formatted.
My arlo pro base station doesnt recognize the usb. I have formatted the USB its a scandisk ultra Flair 3.0 128 GB. I have plugged it into the base station. Once I go to my devices and go to the storage location. I have the toggle "on" for usb storage and 'On" for overwrite. However underneath it states no USB device detected.
Hey kat23wg,
When you formatted your USB device, make sure you formatted it to FAT32. You can read here to learn how to set up Arlo Pro local storage: How do I set up local storage backups on a USB device using my Arlo base station?
Hey Adrian_Frazier,
If you're having problems where your Base Station isn't recognizing your local storage but your computer does, contact the Support Team to further investigate this issue. You'll find several ways to contact support in the provided link.
