Arlo Pro base station not connected
After only 5 weeks, my base stations are disconnected from the Internet so I am off line. How do I reconnect the base stations so I can restore video recording and sharing via my smartphone? If I can't, the Arlo Pro will turn out to be the stupid link in this security system...
You don't say if they are remote or not.... but the usu answer is to power down then back up and they come on line automaticly
If they are remote... not much .
Sometimes you must unpower all and bring up the modem, router , base in that order
As a PS... another user with product in vacation home used a remote wifi ac switch called wemo smart plug...wifi based control and he was able to reboot the base while away ( his router for wifi was still up )
