Arlo Pro base station dead in 3 days
  • 2 Replies
  • 2371 Views
Zephyrus
Hi,
I recently installed a brand new Arlo Pro (Base station model# VMB4000) with 2 cameras at my house. It worked all fine for 3 days and I tested it with my phone.
I went on an office trip happy that I'll be able to use Arlo to monitor my house remotely. My happiness was short lived. Just when I needed it my app started showing that the base station is disconnected and unable to get status.
On returning home I saw that the base station was actually dead. No lights were on. I tried rebooting as well as resetting and trying a different power socket but with no luck. No green or amber lights show up. My other devices in house have been functioning fine at the same socket so dont think it was any power surge issue.
It is really frustrating that a critical system like this can fail so miserably. What are my options here?
Thanks!
Streak2
Master Master
A completely dead base is quite rare.
You could try a different 12v power supply in case it's the power supply that's faulty.
If holding in the reset button for about 10 seconds does not give you amber lights then I would either return the unit for a replacement or contact support.
Streak2
Master Master
Zephyrus
Thanks will contact support. Wonder if power adapter is faulty.
