G'day, I have an Arlo Pro and it's been fine for the last 6 months. Lately, however it's decided that I don't need to use any form of password or fingerprint to log into the app. It used to always ask for my fingerprint or password when I clicked on the app, now it just goes straight in. I have reloaded the app and reset the base station and cameras. I'm a little concerned because I did note that the two step method of i.d. had been switched off and I have switched it back on again, but still no luck. I will reset my password to be sure. Maybe I have to logout each time now, but I didn't need to do that before.
Thanks in advance for your help.
Arlo Pro vmb4000r3
Hi @jim62
Are you still experiencing this login issue?
May I ask what version of the Arlo app you are using as well as Phone/OS?
G'day, yes I'm still having this issue of being able to log in with no i.d. on my phone. The phone is a Samsung A20 on Android version 9. Arlo app 2.13_27035
I have re=installed app too.
Sorry for late rsponse been very busy. Thanks for your help Regards Jim62
HI @jim62
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
