Arlo Pro and Smartthings
Several months ago I had this problem, ( as have many others and many are still having it), but I don't remember exactly what I did to correct it. I wish I could give you a 1 minute answer but, unfortunately you may have to try a few things to solve the problem.
1) Don't try to mix and match Modes with Smartthings - simply allow Smartthings to control everything unless you need to set the audio parameters, etc.
2) Don't use the Smartthings Mode in Arlo at all, in fact you can delete it altogether. Just set your Arlo Mode to Armed and if everything is setup in Smartthings, Smartthings will control everything.
That is the short answer. If what I said above doesn't work, then delete every camera in Smartthings along with its associated Smart Apps, Rules, etc. In Arlo, setup one simple rule for each camera, (camera 1 triggers camera 1 to record video on motion detection). Rename your Cameras to whatever name you wish it to be.
Then go into the Smartthings Market Place > Cameras and select Connect Now. Follow the screens for each model of Arlo Base Stations, (original or Pro), and select the cameras associated with that base station) and connect them - don't forget to also connect your Pro sirens. If you have any Q or Q Plus cameras go back and add them.
Notice that even if you deleted the Arlo Smartthings Mode, it will show up agaain. Don't use it. Only use the Arlo Armed mode.
Now go back into Smartthings and rebuild your Routines, Custom Apps and SHM.
Hopefully, you will not need to use the second choice I gave.
Try that and let me know how it goes. Mine are now working correctly as they were designed to do.
Brian
