  • 4 Replies
  • 2074 Views
Catfish20
I've had Arlo cameras for close to three years, no problems. Starting back on August 10, 2019, three of my five cameras went offline, then a few days later, the fourth wireless camera went offline. The indoor wired camera stayed up and never stopped working. I've removed and readded base station, removed cameras, replaced batteries and resynced. The wireless cameras will come up and work (alert and record) for about 10 minutes and then all activity stops. I can still watch live. So irrittated after messing with this for 3 weeks. They currently don't say offline anymore but they are not alerting or recording (except for the wired indoor camera).
JessicaP
Hey Catfish20,
Are you using any custom mode? Try testing using the default "Armed" mode to see if it'll keep alerting and recording.
What Arlo indoor wired camera product are you using? Have you tried re-plugging your camera to see if that helps?
Did77
Hi,
I had the same problem twice this week.
No recording in the library
No iOS notification
No email notification
Homekit automations doesn’t work anymore
I can see the livestream and the status of my 5 cameras (battery state of charge and wifi signal strength) in the app (iPhone and iPad Pro)
Movement detection is ok (orange light in front of the camera and movement icon turn orange in the app)
I checked the mode (activated and properly configured)
I restarted the base station with no effect
Internet link ok (65 Mbps down - 7 Mbps up)
So i’m looking for help here...
...And it works again without doing something special.
I never noticed such a problem in 3 years of use.
Have you some maintenance in your datacenters ?
I’m living in France
JessicaP
Hi Did77,
Are you still experiencing this issue where you're not receiving any notifications or recordings?
Did77
Hi,
I had this problem twice last week. It’s ok now, I hope it was only a transient problem.
Thank you.
Best Regards
Didier
