My Arlo Pro is placed right outside of my front door and when I try to live stream it, it will not work. Its gives me the "request timed out". I thought maybe the base was to far away at 15 ft. I moved it to where it is only 5 feet away from the camera and still to no avail "request timed out." So any suggestions would be great before i decide to pack them up and return them.
Have you tried both the app and browser to see if one works properly? If using the app, have you tried both cell and WiFi service?
The issue with the connection is anyplace between your device, the servers and the base. Consistent issues would seem to be relative to your device but not necessarily.
That could be for a variety of reasons. A metallic film on the window, dense wall material, wiring, ductwork, etc. all get in there. What if you move it a couple/few feet to either side of the current location - any luck? Bring it inside again and try various locations with varying distances to see if the symptom recurs. Swap cameras to see if stays with the position or the camera.
