I live in Australia. I purchased the Alro Pro 3 camera pack from USA.
Obviously, I cannot use the supplied Wall charger.
I am looking for an off the shelf replacement.
I need to know:
Min Voltage: ? 9V (I've seen in other topics to charge)
Amps: ? (minimum required at 9V?)
USB: 2.0, 3.0? - does it matter?
If anyone has purchased something from Officeworks, JB, Jaycar, etc and can send me a link that would be greatly appreciated.
Thanks.
Get a travel adapter and use the one that came with the camera. I tried using another Qualcomm based charger and it fell short on voltage. Just first, check that the power adapter says 110V-230V on it, which I'm sure it does, because that's what I use
Good call, I'll check that tonight.
