Arlo Pro VMS4230 - Motion and Sound Not Recording
  • 2 Replies
  • 4939 Views
  • 3 Likes
korbelreno
Hello Community,
I received a low battery notification and changed the battery (I've done it twice before-no problem).   Now, the camera does not record motion or sound. The little running man and ear remain gray.
I have done the following so far:
Reset the OEM battery - nothing
Reset the first OEM battery after charging - nothing
Removed/added the camera - nothing
Reset the Base - nothing
Unplugged/replugged the Base - nothing
What else can I try?  Your help will be much appreciated. Thank you.
steve_t
Master Master
The running man and ear being gray indicates an issue with your mode or rule for that camera in that mode. If you change the mode to armed, do the icons turn black and the system works? You may want to create a custom mode from scratch with rules that suit your needs
steve_t
Master Master
korbelreno
Thanks, Steve for the help. I changed it from custom to Armed and that did the trick. Thanks again.
