Arlo Pro battery will no longer charge with the supplied charger that came with the kit. The charger lightning bolt is on and green, but the battery charge percentage never goes up.
Best answers
If youo let it discharge completely, you can run into this. Try this FAQ - the key is to plug in and unplug many times to get enough charge into the battery to then allow it to charge properly. Recharge proactively.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
