  • 1 Reply
  • 9029 Views
Thumpersma
Can I record video while the ARLO Pro is plugged in to charge the battery? In other words, I'd like to be able to plug in the camera and charge it while still being able to use it to record video in the specified area. This will essentially make it a wired camera, I suppose. But just wondered if I needed to take the camera off-line in order to charge the battery.
Thanks.
Yes you can ... you can also pull the battery and run just on the ac adapter if wanted
