Arlo Pro Stopped Recording For 10hrs Then Started Recording Again?
I have an Arlo pro with 2 cameras and today I noticed that it stopped recording activity for 10hrs and then just started to record again I was wondering if anyone has had this issue and why this occurred.
Zander545,
Did your camera appear offline, or was there missing recordings of an event that occurred?
No it didn’t go off line it seemed to not detect anything for ten hours I went onto my app to check on all the activity for the day and there was 10hrs with no motion detected. I know your prolly thinking there was no activity but I live on a very busy street and I usually get a minimum of 400 plus notifacations every day so this was very unusual. I’m hoping someone might know why this might of happened.
Zander545,
Has this issue happened since the last occurrence? Was this on both cameras or just one? Have you rebooted your base station & remove/re-insert the batteries?
There is a chance the internet had a hiccup, or there is interference happening within the area causing a disconnect.
