Arlo Pro Steam
Hi,
I realized i mounted my Arlo Pro Camera about 2 feet from the vent for the washing machine. When i dry clothes, hot steam comes out. My camera was slightly wet from this steam. Will steam be an issue? I know its water proof but since steam is vapors, it maybe able to go through areas where liquid cannot? I notice the vents for the sound have holes.
I guess you mean the vent for the dryer... 🙂
It shouldn't harm the camera, but it may cause condensation on the lens which can make it blurry...
I would move it or add a deflection flap so the water vaper goes the other way.
