Arlo Pro Status Missing When In Schedule Mode
When checking the staus, armed or disarmed, in schedule mode 1/2 the time there is no staus indicated just the clock indicating im in schedule mode. other timesis shows armed or disarmed next to the clock. This is an issue as you cant tell when the cameras are armed or not.
Check it on the web access .... https://arlo.netgear.com/
sometimes the app and web show differently
Could be a problem with latest app update if you are set with auto updates. Try app uninstall and reinstall.
Its has been like this for the past 4 or 5 updates. I keep thinking each update is going to address this issue and it keeps getting over looked.
It does show the schedule status consistantly when accessing through the web. Its definatly an issue with the app which is how I check my cameras 99.5 % of the time from the road.
