Arlo Pro Sound feature with Old Base Station
  • 1 Reply
  • 4672 Views
StanS
I'm interested in purchasing the Arlo Pro for its two (2) way sound (Mic/speaker) and want to make sure it will work properly with my older Base Station. Will the sound work with this configuration on an older Bas Station?
Thanks!
Thanks!
Yes... I'm running a PRO on the older Arlo base right now for testing purposes .
Can say have really have no problem, PRO sync'ed right up as a Arlo cam does.  Audio and mic feature are there in the same web browser app.
I'm finding the audio coming out of the PRO not very loud, but loud enought to hear from 20+ft away from where I normal sit at computer... Mic working fine on the web (Fire Fox ) and will be testing ipad/android soon.  Finding a 1-2 sec delay in speaking to hearing the voice come out the far side.
I also like the fact it works in the same schedule as the regular Arlo cams ( not a separate schedule like the Qs )
Any other questions , feel free. ( or any thing special you think I should try )
