  • 4 Replies
  • 2905 Views
feldeee
My Arlo Pro is VMB4000- Can I trigger the base station siren from a remote location?  I would assume that I could set the siren off if I did see someone in my house, but I couldn't find anywhere that showed me that option, armed or disarmed.  Thanks for your help.
Sorry if this gets sent twice, it doesnt look like the irst one is sent
yes you can...
On the apps, it is a pull down tab in center top of the device screen
djtimster
I have 2 systems (different locations) that I am monitoring, how do I know I am Alarm triggering the correct base station?
Rename you base sirens in Settings, My Devices, your base. Use the second base selection (just below the first one).
feldeee
I found it, thanks
