  • 1 Reply
  • 3766 Views
Sulaiman
There seems to be a common issue with myself and others regarding the siren not going off on the Base Station when either manually triggered or when motion is detected. The only solution that seems to work is a reboot of the base station, but that doesn't sound like a very practical solution to perform every now and then.
The whole point of a security system is to know that it works to have a piece of mind especially when you're not at home and traveling, Arlo Pro doesn't seem to tick that for me as this issue keeps persisting. If worst gets to worse there is not guarantee that the alarm would go off when needed if someone breaks in which defies the whole purpose of the system itself!
I hope a permanent solution would be available ASAP.
P.S. I'm running the latests firmware/software updates across all my devices; cameras (v. 1.090.0.0_9945), base station (v. 1.8.2.4_10232), and iOS App v. 2.3.2)
I'm going to guess it's a problem with the base.  Open a case with support.
