Arlo Pro Siren Button Missing In App
Have lost ability to arm siren ( turn siren on ) in mode setting
Now have to delete Arlo, then add device to arm siren
the only option in the Arlo siren box in mode is do nothing
I just tried it using the Android app and it works as expected. Try restarting the base as well as reboot the phone and reinstall the app.
I tried all those several time on iPhone and base station with no changes
this problem began after latest firmware update
Tried all that several times no change
using Apple iPhone with latest firmware
problem began after latest Arlo pro firmware update
worke fine with no issues before update
I have tried those procedures several times and no luck
I am using an iPhone and iPad and the turn siren on in mode settings is gone
rodzulu,
Have you tried using the Web Client to see if the alarm setting is there?
