When setting up a Schedule us there a way to adjust the motion sensitivity? I can't find a way to adjust it. And if not what is the default motion sensitivity?
The SCHEDULE tho in the section for modes is not really a mode... It is just a timer that turns on and off the MODE you have selected.
So, to make any adjustments, you must go into and EDIT the MODE you are using ( done outside of schedule )
IIRR, default is 80%
So for example, if I'm in Geofencing mode, will the Schedule rules still be in effect? It's confusing cause I can't enable both modes at the same time.
In GF mode, you can select either a specific mode or the schedule for Home or Away, as defined as you set up GF.
