Arlo Pro Requires Removal Of Battery Daily To Detect Motion
  • 2834 Views
Phelps
My one month old Arlo I got as a gift has stopped detecting motion consistently unless I remove the battery & put it back in daily.. I can see live fine and it use to work fine without this happening but not anymore. It’s ridiculous. What would cause needing to take the battery out and put it back in daily???
Restart the base. You may also want to try removing the camera from Settings, My De ices and resyncing. It's also possible that a weak signal between the base and camera is the issue as well as possible interference from other 2.4GHz devices such as cordless phones.
Phelps
I restarted the base and still the same thing. We don’t have anything wireless in the house aside from tvs. It worked fine the first month so I’m confused why suddenly it wouldn’t.
Does resyncing mess anything up? I would think live view wouldn’t work if it wasn’t synced, is that wrong?
The only things that resyncing messes up are the specific camera settings and custom modes (you'd need to re-add them to your modes). The default Armed mode automatically gets any new camera but settings would have reset for it.
