  • 2 Replies
  • 2559 Views
jamesheffington
Moved unit from another location. Attempting to set up innew location, with new network. Cannot locate base unit.
Streak2
Master Master
What lights are showing and what color on the base unit?
Here is the quick start guide.
https://arlo.com/en-us/images/documents/arlopro/arlo-pro-bestbuy-QSG.pdf
Simply moving the system shouldn't cause you to have to set it up again. If you reset the system then you need to do so.
